Thread: SO... How many are actually using HDRx?
Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 54
  1. #31
    Quote Originally Posted by Nils Ruinet View Post
    But honestly, most of the time you don't even need HDR with the MX sensor. And my guess is that Dragon will probably make that feature nearly useless. Wouldn't be surprised if they decided to drop it and use the extra processing power for the 6K sensor.
    Well, it might be useful for tracking, so I'm not sure HDRx is going anywhere. With 15 or 16 stops of native DR on Dragon I expect it not to be in use often, though :)
    Senior Member Björn Benckert's Avatar
    Dec 2007
    Stockholm, Sweden
    We did a 4x5k 98fps 360 panoramic stich work shot in kualalumpur for US citybank half a year back. Then the HDRx was a necessity. As we shot all diections, and had location some indoors with big windows and heavy sunlight etc. To me the HDRx function is the VFX plate king. we got some cool nuke setups that works with UP 8mm and epic 5k in four directions.... renders out some really prestine canvases at about 12k wide...
    Björn Benckert
    +46855524900 www.syndicate.se
    Flame - 3D - Epic - HAWK C 35-135mm - Milo MoCo - Droidworx Mikrokopter
    Braunschweig, Germany
    I found DaVinci Resolve very helpful in such situations, where you can treat the two tracks independently.
    You can fill in the X-track with a power window where you need it and protect your skin tones from it in most scenes.
    Regards,
    Uli
    My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy.
    HDRx has a lot of promise but hasn't panned out too much in actual practice. I had high hopes for several HDRx shots we shot for our casino commercials recently, but they were difficult to make work. Even our colorist, who is one of the best in the biz, wasn't set up for HDRx in his Resolve - which means the biggest TV spots and music videos aren't using it either.
    Blending in RedCineX just darkens the overall image. Using After Effects and pulling a luma key kinda works, but still makes things look weird. I ended up rotoscoping the A-track out to use the highlights from the X-track in one shot in a hotel room where the window was blowing out. I wish RedCineX was more intelligent about the blending between the two. Like a video version of the Nik software plugin HDR Efx Pro.
    Red One #4935 and Epic-X
    Pechanga Resort and Casino
    Video Production
    Senior Member Timur Civan's Avatar
    Jan 2007
    New York City
    The trick is to use magic motion, then get your highlights where you want them, then use a combination of iso and curves to get where you want to be. At least ive had it work out just fine using that method.
    Director Of Photography
    RED Epic M - Fujinon Cabrio 19-90 T2.9 - Oconnor 2060 + accesories
    www.TstopCinema.com
    Timurcivan@gmail.com
    9175894424
    Senior Member Justin O'Neill's Avatar
    Jan 2007
    San Diego/LA/Seattle
    Yeah, curves work very differently with HDRx shots then with non. It's definitely something you have to play around with and get the feel for.
    Belgium, Antwerp/Ostend
    I've used it on a few shots, but it's true that it's power should be worked on in redcine and other applications.
    you have to treat the tracks independantly like with the power windows of Davinci or Scratch to get the most out of it.
    2x Red Epic, audio and image postproduction in Antwerp. 2x recording studio with 5.1 surround.
    www.nuhollywood.com
    Yes, I agree that a smarter tool should be incorporated into RedCine-X, I have used it only once with limited results with the blend tool, I'd love to see something more imaginative from the Red Team in this respect
    Mar 2011
    Toronto, ON Canada
    Combining two exposures in video and making it look good is not an easy task. Even in photography taking multiple bracketed photographs and making it look great is tough enough. There is no magic solution. That said, it's reassuring to have the extra track's info just in case you blow it - literally.
    ___________________________
    10 frame handles
    Vimeo
    Scarlet #329 "HAL"
    Norway
    The Magic Motion sorta works.
    But I'd have loved to have more manual controll over it right there in RCX.
    Life is good. So is RED...
    http://youtu.be/mhFB1CMzQBM
    http://bit.ly/mCwcoN
    Twitter: gunleik
