Thread: Strange color in rendered clip - Resolve 9
Results 1 to 5 of 5
  1. #1 Strange color in rendered clip - Resolve 9
    I'm new to DaVinci and I'm trying to work between Resolve 9 and PremierePro.
    I've graded my clips, now I'm exporting a Quicktime 4444 1920x1080 from Red EPIC RAW footage.
    The clip I've exported has some strange colors appearing in some frames, see the attached file.
    Also, I get a single line of black pixels on the left of the frame, it seems the clip it's 1920x "1079"...
    Can someone help me with this?
    thanks
    Junior Member
    Dec 2010
    it seem its a problem with you CUDA driver
    Use these step :- in output module you have a option called Render at % of full speed if you select maximum put it on 1 % of full speed
    Aug 2010
    There is a known issue with OpenCL 10.7.4 which I suspect you are running into. Can you confirm your exact hardware/OS configuration?
    I also have a black bar on the left in prores 4444 from r3d files.
    I believe this might be a beta bug. Scaling to 100.04% fixes it temporary.
    No false colours.
    Mountain lion, davinci beta 3, hacked gtx 480, 2009 mac pro.
    Jonas
    Showreels
    Ok, rendered at 1% and solved almost every problem with false colors, except for 2 clips with blown highlights that were still rendered with black clipping. I've managed to go back and make some correction and solved everything.
    My system is an iMac 2011, i7 3,4ghz, AMD Radeon HD6970 1GB, Lion 10.7.4
    Still have the black bar problem, solved using the tip from Jonas and scaled to 100,4%
