Thread: Camera Converged or Parallel?
Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1 Camera Converged or Parallel?
    Senior Member Rich Schaefer's Avatar
    Mar 2007
    SoCal & Tyrol-Austria
    I have been a believer in shooting in camera converged and I have been doing so, but I think I am becoming a believer of shooting parallel. I wanted to see what the other shooters of stereo were thinking these days?
    I should also add that John Schwartzman shot parallel on the current Spiderman and I thought the stereo was very well done and most of all very easy 3d to watch.
    Below are the pros and cons of each in my mind. I see there are two reasons to shoot converged and 3 good reasons to shoot parallel
    Pro Converged arguments:
    1. There is a little, perhaps 5%, more perceived roundness on objects but you really-really have to be looking for it to notice it.
    2. Its easier to shoot converged because it displays 3d well on the onset monitors unless you use a convergence box like a Davio.
    Pro Parallel arguments:
    1. I think it is an easier to view and resolve the 3d, because the sides work/fuse better because the cameras are pointed in the same general direction.
    2. In post there is no Key-stoning to correct like there is in camera converged meaning potentially easier/faster post production.
    3. Due to the nature of optics being very good but not perfectly square, keeping the anomalies of bend and barrel distortion of the two images pointed on the same points will make for a better match once blended in to one stereo image.
    Here is a test I did, one is camera converged and one is parallel and converged in post . They are maybe 15 seconds apart with the same IO. The red letter on the left "C"=Converged and "P"=Parallel. Check them out here on youtube 3D:
    http://www.youtube.com/watch?v=8kAFnfOE0_g
    What do you guys think these days?
    Thanks much!
    Rich
    3 Epics! M462, X108, X1266
    Epic 3D Beamsplitter 3D Rig-FIZ controled, 3D S/S rigs, Excellent 8ton G&E Truck!
    2 RedOnes #115 & #3090
    Local 600-D.P.
    www.highimpactpictures.com
    Oct 2007
    Quote Originally Posted by Rich Schaefer View Post
    h
    There is potentially more resolution with converged as there less crop applied from the HIT transform with parallel filming.
    Im not sure I agree with 2. As you mostly not converging that much in camera that keystoning is an issue in post.
    With both techniques/tools exist in post for good image alignment for Converged or Parallel filming. Both techniques are equally valid depending on the sequence in question. The most important thing is matched lenses and rig alignment.
    Mar 2007
    Quote Originally Posted by Dave Blackham View Post
    There is potentially more resolution with converged as there less crop applied from the HIT transform with parallel filming..
    True, I did have to blow up the in camera converged so they would appear the same size. It was by 2% that I zoomed in. I would shoot at least 4k for stereo to have extra pixels for post fixes.
    I'm not sure I agree with 2. As you mostly not converging that much in camera that keystoning is an issue in post.
    I recently had a great series of steadicam shots we did that were shot side by side rig, camera converged, shot with 11mm lenses into a stadium with lots of detail. I spent some time with those shots in post and the key-stoning was severe. It was those shots were it started to occurred to me that I would not have this problem if the cameras were parallel.
    Local 600-D.P.
    Banned
    Oct 2007
    Tasmania
    Rich, you are absolutely right.
    It is maths, or specifically geometry and common sense that the entertainment industry has been historically slow to adopt.
    It can be argued that the resolution loss resulting from correcting the key-stoning is larger than that from HIT. But it is difficult to correct the asymetric geometric distortions in left and right eye as the lenses rarely render the field flat and undistorted. And, more importantly, when shooting converged, the image planes are no longer parallel, so that the focus on each side of the screen falls at a different distance on left and right eye. This is not assisting the brain to fuse such images together and can not be "corrected" or compensated for in post.
    Convergence (toe-in) gained popularity in live 3D broadcast as a "cheap", or rather gimmicky, way of adjusting the depth at which the image appears to the viewer. Complex systems, like CPG Fusion 3D, have been developed and marketed convergence linked to focus as a desireable feature, for example. Hype over science. It happens all the time.
    On a side but related note, I know of some clowns advocating convergence when filming underwater through a flat port without understanding that it works like a variable chromatic aberration and asymetric distortion control allowing the user to change them from "severe" to "ridiculous" and anything in between. Welcome to the entertainment industry! :)
    Oct 2007
    Quote Originally Posted by Pawel Achtel View Post
    It rather depends on the sequence of course as to which technique you wish to use. Both are used to good effect when done properly and used by professionals all the time. Theres much more to 3D than sharpness of image, Variable IA and convergence including the ability to work to small IA are essential to the normal in air environment as well as Underwater of course.
    Banned
    Oct 2007
    Tasmania
    David, this thread is not about IA. We are discussing convergence (toe-in).
    Can you explain how convergerce produces good effects "when done properly" or "used by professionals"?
    I don't think geometry or physics change depending on who is doing it. You either converge or shoot parallel and do HIT.
    What do you mean by "done properly"? Rich and I believe that we should always shoot parallel and both Rich and I put strong arguments for it.
    You are also incorrect about sharpness disparity between left and right eye, which is what you will always get when converging. It is bad. If you think the same focus plane for right and left eye are not important, please explain why because I'm not getting your point of view.
    While you can get away with toe-in on long lenses, I don't understand why convergence is desirable or "essential", as you write.
    I believe that convergence is a form of tax on cinematographers that do not understand geometry. :)
    On Spiderman John decided to go parallel on good advice from Rob Engel. We did allow for crop but we were Epic so that was easy....Viewing video assist in Parallel was no problem and convergence is always manipulated in post no matter what you do in production...
    In my mind it is a win-win situation to shoot parallel IMHO
    Banned
    Oct 2007
    Tasmania
    Thanks. Totally agree with you, Peter.
    Mar 2007
    Thanks for the replies everyone! It sounds like I am not alone on my thoughts about shooting parallel.
    Pawel,
    I totally agree, all of your arguments make sense. I don't know how anyone can think shooting toe-in under water would be better. I would sure think keeping the light as parallel through the port would lend to less light bending, fringing and aberrations...
    Peter, thanks for the confirmation, and yeah, I agree, win-win!
    Local 600-D.P.
    Mar 2007
    Whats everyone else doing, camera converged or parallel?
    Local 600-D.P.
