Thread: Best Place to Give Feedback on Resolve 9 Beta?
Results 1 to 9 of 9
  1. #1 Best Place to Give Feedback on Resolve 9 Beta?
    Senior Member Peter Moretti's Avatar
    Apr 2008
    I'm wondering where the best place is to give feedback on the version 9 beta? Here, on BMD's own forum, Creative Cow? Of course, that assuming BMD wants to hear my $0.02, LOL!
    1110001100010102
    Senior Member Steve Sherrick's Avatar
    Boston
    Peter C from BM hangs out here sometimes, so feel free to post here and directly to their team at davincihelp (at) blackmagicdesign (dot) com
    I would say it's useful to post here as well because there are many people beta testing it and maybe some of your findings would be useful to the community.
    Steve Sherrick
    Chief Collaborator
    Modern Vintage Media
    STEVESHERRICK.COM
    Local 600 DIT/Operator
    Senior Member Marc Berger's Avatar
    Dec 2007
    France
    Great! First question: I have a 25P project. Everywhere I possibly could I was changing the presets to 25p (psf), but if I go to the delivery tab I can only output 24p or 23,98. Is this a bug or a limitation of the Lite Version?
    Thanks,
    Marc
    Apr 2009
    Singapore
    It's likely when you added the clips to the Media Pool that the conform frame rate was set to 24fps. On that basis the deliver page frame rate options will be 23.98 or 24.
    Try setting the conform rate to 25fps prior to putting clips into the Media Pool and see if that gives the result you're looking for.
    As for feedback, you can post here, on our new forum or directly at davincihelp (at) blackmagicdesign (dot) com
    Peter
    Senior Member jake blackstone's Avatar
    Nov 2007
    Quote Originally Posted by Marc Berger View Post
    Thanks,
    Marc
    Great question. As far as I know, in V8, if you had started your session with the wrong frame rate, there is no way to change it, other than starting again from scratch. Haven't looked at it in V9. Hopefully it changed. I got burned with this once.
    Also, why is the default at the start of the new session in auto save tab is set to OFF? Again, speaking from tragic personal experience of losing the whole session...
    Apr 2008
    First off, thank you BM for offering such an amazing application!
    I've noticed right off the bat in the PC version that window management is very odd. None of the standard minimize/resize/maximize and close buttons are in the upper right of the main window. And it seems like it is always pinned to the bottom of the screen. This makes resizing and repositioning rather challenging.
    Hope that feedback can be helpful.
    1110001100010102
    Dec 2007
    France
    Quote Originally Posted by Peter Chamberlain View Post
    Peter
    Thank you Peter. This did it. I found out, that I could not change it, because I didn´t scrolled down the page in the "Master project settings"until the bottom. I tried to change the "conform options" without scrolling down to the bottom( The way I can see it when I open the Master project tab), and it shows only 24 and 23,976, and not all the other options.
    Marc
    Senior Member Paul Provost's Avatar
    Aug 2008
    Quote Originally Posted by jake blackstone View Post
    Yeah this is a problem. Please default to on.
    Colorist | Hollywood, CA | www.4kfinish.com
    Apr 2008
    AFAICT, the Help menu does nothing. I'm using the PC version. Hope that helps you guys.
    1110001100010102
