So I went out shooting tonight and while I was out there my Red started doing some weird things. First off the timelapse function didn't seem to work at all in 4K 2:1, as that was the only setting I was using tonight. Then after I did a 1fps clip that lasted for 45 minutes or so it took about 15-30 seconds to post after I hit the record button to stop. I also got this long post time on short clips as well. I then tried to record another clip after that but I got a record error and the image on the LCD was playing back a couple frames on a loop. The camera wasn't in playback mode when this was happening. I could change settings but nothing I did you change the image in the LCD. I would have to power down the camera and then try again. The camera did this about 3 times back to back. It would do this in both the 1fps mode and in 24fps. After the 3rd time powering down and powering back up the camera worked fine. I guess I need to stick with build 13 for the time being because 14 has got some gremlins running around in it.
