Thread: dpx / timecode issue
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 dpx / timecode issue
    Junior Member
    Feb 2008
    Hi all,
    another timecode issue regarding dpx-export:
    in RedCine Build82 WinXP: loading 2 scenes, doing simple edit (change in and out), export as dpx-file sequence
    what happens is:
    the dpx timecode has an offset to the original source timecode. unfortunatly the offset changes from event to event - so no possibility of (easily) changing it afterwards. it happens whether you export to folders or as one sequence. Interesting 1: a burned-in timecode is correct, the metadata not.
    Interesting 2: the status line is red during rendering and shows the wrong timecode and remains red afterwards. before rendering it is white and shows the correct TC
    This happens using manual edit in RedCine and using the xml variant. I havenīt found any solution yet.
    I donīt think it is the 24fps/25fps issue - as Project is set to 24fps and Metadata say it is shot 24fps
    I need the correct dpx timecode to continue working with the files. Scratch is not an option, we are using Baselight. I read that some people are having the workflow FCP-RedCine-Baselight/Resolve/Lustre. So they must have the same problem. Or is it only me?
    Any help/tips appreciated
    Regards,
    Tom
    Hi Tom
    Did you find a solution to this problem?
    Junior Member
    Feb 2008
    Hi Kjetil,
    no unfortunatly not. I also tried the Mac Version but always when I try to export dpx files (from an edited clip or sequence) the dpx timecode has an offset and is therfore unusable for me.
    Do you have the same problem? I am still wondering why I didnīt find any other thread regarding this issue as I would think ther should be more people with this problem.
    Regards,
    Tom
    Just got my camera and I'm doing tests next week trying to find a pipline with DPX as the end result. This worries me. I've noticed the TC slot in shot setting is a slider and can be changed manually. Could it be that we have to manually set TC to match the new in point?
    We can only hope that the next Redcine (should have been here already) has at least these major issues resolved. How can we possibly do a conform from offline without proper timecode?
    Quote Originally Posted by voivod View Post
    Hi all,
    what happens is:
    Regards,
    Tom
    What software are you using to read the DPX metadata?
    Lucas
    ASSIMILATE, Inc.
    LA, CA, USA
    Junior Member
    Feb 2008
    Hi Lucas,
    read the Metadata with Fusion 5.2 and Baselight four.
    I made another test:
    load shot into RedCine.
    Metadata Info in RedCine says: Start Run Record / Edge Timecode: 01:02:08:19
    in Shot Settings it says 01:02:08:18
    Burn in Timecode: 01:02:08:18
    Export dpx - dpx Metadata 01:02:08:19 while the burn in shows ...:18
    if you activate Project/Display Guide Settings/Show Source TC: 01:02:08:19
    and finally if you export to Quicktime and use Metacheater utility to extract TC: 01:02:08:18
    so this would mean an offset of 1 frame to the dpx export.
    this could be handled, but the offsets regarding an edited export from RedCine are much bigger and not consistent.
    Maybe it all starts because the player starts counting with 0 but the shot settings use 1 as start? (the overall lenght is correct)
    Many thanks for getting involved
    Kind regards,
    Tom
    Junior Member
    Feb 2008
    I did another test with different material:
    dpx export and timecode was correct when exporting a single shot (no offset)
    BUT
    after editing 2 shots in RedCine and exporting as dpx the timecode still has an offset
    for example:
    first edit starts at 01:02:41:23 (correcly shown in RedCine and Burnt in) - dpx metadata shows ...:41:19
    second edit starts at 01:00:46:16 (correcly shown in RedCine and Burnt in) - dpx metadata shows ...:46:06
    Can somebody replicate this problem? And is it a bug? - or is there still something I am missing? Any help/ideas very appreciated.
    Kind regards,
    Tom
    BUT
    for example:
    Kind regards,
    Tom
    Tom,
    I know several facilities using REDCINE to generate frames, and have privately asked them and they do not report the same issue. So... let's figure it out...
    My first thought - does your framerate in REDCINE match the framerate of the clips?
    Lucas
    Junior Member
    Feb 2008
    Lucas,
    thank you for your effort.
    Yes, the framerate of the shots is 24fps and project settings are 24 fps (default)
    Tom
  10. #10 re: 4K 16:9
    Junior Member
    Nov 2007
    4K 16:9 - DONT USE - unless you are going to create a DPX sequence, dump onto a timeline (i.e. Baselight), set a new timecode and make HDSR masters - then bsp for offline.
    There is little else you can do with 4K 16:9 in REDCine.
    4K 2:1 - All the software works - thats to say RED Alert & Quicktime exports with time of day t/c.
    David J Phillips
    The Mill London
