Hi all, I dont know if this isue has been known before what it could be since i havent read all the posts.
Ok you have the varispeed prepared you have set your speed and you have check the varispeed checkbox, if you change your battery, and reboot the speed will be in the value you stated, the checkbox will steel be checked but it actualy want record at your desired speed. Is not that bad because it advises you in the lcd because it shows the current speed and you will see it white to whatever speed you have the proyect.
This is with build 13.
I havenīt had time to check it with the 14 th I hope to do it this weekend.
Have a nice day and if you try it in your cameras with the 14 just say it. Or maybe somebody from RED can give some more info. Thanks in advance guys I know you will
Jon Corcuera
