Thread: Filter Case
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Senior Member Brent J. Craig's Avatar
    Aug 2007
    Toronto
    Quote Originally Posted by jtm View Post
    do you have a weblink to the company?
    Google A&J cases
    First link
    http://www.ajcases.com/
    (PS - opt for the 'Text Only' website unless you have some sort of Star Trek communicator that can click on moving links. If we buy enough cases will they execute their web designer?!?)
    The best thing to do is just call them and tell them how many filters you have and roughly how you would like the case layed out then they will send you a quote. Mine is a Di Lite case and is VERY light weight. Here's their contact info:
    A & J Cases
    11121 Hindry Avenue
    Los Angeles, CA 90045 (800) 537-4000 toll free
    (310) 216-2170 voice
    (310) 216-2694 fax
    Jim Logan
    Logan Productions, Inc.
    8035 N. Port Washington Road
    Fox Point, WI 53217
    414-352-9691
    jim@loganproductions.com
    www.loganproductions.com
    A couple of you have asked for a picture of my A&J filter case. I grabbed a 4X4 case and took a couple of quick shots. A&J will make cases to accomodate any size filters.
    I also should mention that If I had to do it all over again I would have them include a small compartment in the back to hold a few soft filter cases for those "run and gun" situations when you want to have a filter or two with your assistant or in the ditty bag. Would also be a good place to keep a cleaning kit.
    Jim Logan
    Fox Point, WI 53217
    414-352-9691
    Senior Member Michael Panfeld's Avatar
    Nov 2007
    Washington DC
    That's a beautiful filter case. I already have a similarly-sized extra ATA hard case and a few extra Pelican 1550 cases. Somebody said something about ordering custom cut foam. Plus, those white inserts in the A&J case look so simple. Any ideas on where I would start if I wanted to order just the foam or the white inserts? Thanks
