Click here to go to the first RED TEAM post in this thread.   Thread: Firewire 800 connector problem
Results 1 to 10 of 10
  1. #1 Firewire 800 connector problem
    Hi there; anybody else having trouble inserting the firewire 800 connector into the red raid? We have two and although the drive connector looks close there is a |_| shaped metal tab that seems to be shaped more like \___/ on the drive and the connector won't seat.
    Don't want to force it!
    Thanks.
  2. #2 fw400 or fw800
    they are physically different connectors but the red raid has both so use the one that fits.
    http://images.apple.com/support/mac1...onnect01-2.jpg
    the one on the left is firewire 400 and the right one is 800.
    Quote Originally Posted by wigby View Post
    The 400 connector works just fine the problem is with the internal workings of the 800 jack. The cable we have plugs into the apple and aja HD/IO box just fine but won't go into the drives. Don't know what's going on, but thanks for the reply.
    is the connector the same on both ends? maybe the red raid's case wasn't milled properly and it's blocking your connector? can you send a pic of the connector side of the red raid?
    Senior Member Alexis Hanawalt's Avatar
    Mar 2007
    Los Angeles, CA
    800 connectors often don't seat very well - if it's making contact, that may be as good as you'll get... it'll still wobble.
    Alexis Hanawalt
    Bolster Camera, Inc.
    www.bolstercamera.com
    Quote Originally Posted by Cinewalt View Post
    No such luck Alexis, can't even get it to go in at all. Will try to get some pix up tomorrow.
  7. #7 Pictures of connectors
    Here are the connectors
    Left = Firewire 800 plug
    Middle = Red Raid
    Right = HD/IO box (this one fits)
  #8
    RED Bomb Squad Sean R.'s Avatar
    Aug 2007
    That appears to be the wrong fire wire cable. You need:
    http://en.wikipedia.org/wiki/Image:Firewire800plug.jpg
  9.   This is the last RED TEAM post in this thread.   #9
    Aug 2007
    Thanks, didn't know there was more than one style, we are looking for one right now.
    Fun getting all the bits together!
