Click here to go to the first RED TEAM post in this thread.   Thread: RELEASED: BETA REDCINE (v1.0.4)
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
  1.   Click here to go to the next RED TEAM post in this thread.
  #21
    Quote Originally Posted by SF Geek View Post
    That doesn't work on my redcine. Maybe on scratch. I control select and when I hit trash nothing happens. That's what I get.
    Try ctrl clicking on the Slots AND the Shots then delete. This is only necessary when deleting multiple clips.
    Kevin
    Quote Originally Posted by david james View Post
    ...can you output DPX sequences from 4K 16:9 r3d with time of day t/c included in the DPX header metadata?
    thanks,
    David.
    Yes.
    Lucas
    ASSIMILATE, Inc.
    LA, CA, USA
    Things are looking up!
    New version seems a lot more stable, has not crashed on me yet. I no longer get those blue screen buffer errors if I try check at 4K full-res high. Playback seems a bit better... Man, I am so close to having half-res high playback on this system, it's like right there except for the occasional frame hiccup.
    I have not had a chance to test out everything, but renders of 4K DPX are definitely a lot faster for me. 4K 2:1 out to full res DPX I clocked at 2min 2.8secs for 210 frames. The same scaled and output to 2Kx1K DPX took 1min 44secs.
    Like I said, more stable, I can work in photoshop while REDCINE is crunching away on the second display -- that's a first and I've been doing it for over an hour. (frantically knocking on all wood within reach).
    REDCINE process bar still turns red for DPX output (is this normal?) Occasionally text on process bar flashes from white to red for a few frames. What does this mean? All output seems just fine so far.
    - Jeff Kilgroe
    Jeff,
    Are you using Quicktime 7.4.1 ?
    Dave
    Footage shot in 25 fps says 24 fps in the metadata....
    How do I copy color settings to entire timeline?
    What system are you on?
    Quote Originally Posted by Dave View Post
    Jeff,
    Dave
    Yes.
    Quote Originally Posted by Kjetil Haugen View Post
    Mac Pro 8-core 3.2GHz
    16GB RAM
    nVidia 8800GT 512MB
    Dual 30" displays (Dell) at 2560x1600
    OSX 10.5.2
    QT 7.4.1
    All updates installed current, including Leopard Graphics Update 1.0
    I'm working off a RAID that can sustain 190MB/s write, 220MB/s read.
    - Jeff Kilgroe
  9. #29 Dell Latitude or Dell XPS not working with H.264
    Senior Member Andrew M.'s Avatar
    Jan 2007
    Virginia EPIC #2441
    Same problem as on previous release of REDCINE.
    Dell XPS with GF 8700 NVIDIA will not output to H.264
    Laptop has 4GB memory and NVIDIA GeForce 8700M GT with 256MB, OS XP-32
    09:07:08.65 ERROR: QT Codec: CRASHED during compressing a frame..
    : Frame: 2048x1152 - 16 bit
    09:07:08.65 ERROR: QT Codec: Failed to compress frame (error -1)..
    : CG Render - Total: 0.174 Setup: 0.000 Render: 0.174 Read: 0.000
    :Pre TX define 1: OpenGL Error - Out of memory
    Andrew
    Oct 2007
    Having issues with multiple file outputs. I've got multiple clips lined up and REDCine ctd's everytime it gets to a specific clip. My first two clips are 3k, and the third is 4k...crash occurs at the first frame of the 4k clip. If I move the 4k clip further back into the sequence, say after 4 or 5 3k clips, all 3k clips render fine, and the 4k again crashes.
    This occurs regardless of codec, project size, and scaling settings.
    Any ideas?
    QT 7.3.1 of course
    MacPro 8-core 3.0ghz
    4gb ram
    nvidia quadro fx4500
