Build 4 is finally here.. A whole whack of new goodies in this one.
Happy Holidays all...
EPIC: https://www.red.com/downloads/50d4b905a48c372a96001721
SCARLET: https://www.red.com/downloads/4f8c3e5f2f74a94ac2000419
REDMOTE: https://www.red.com/downloads/4ff5d4c526465a1e4600316d
Significant changes since previous build v3.3.14:
* Updated UI
* Added Pre-Record
* Added Time Lapse
* Added Record Ramp Varispeed
* Added Vertical Monitor Flip
* Added Vertical and Horizontal UI Flip/Mirror
* Added Custom Overlay
* Added Power Save Modes
* Added User selectable 1:1 zoom
* Added Selectable LCD Frequency
* Added Import/Export user cal maps
* Added Calibration warnings for exposure and temperature
* Added Luma Ramp Test Pattern
* Added Pro IO and Monitor Audio Mixer
* Added internal frame summing for long exposures
* Added internal frame averaging capability (advanced noise reduction)
* Added REDmote Auto Pairing
* Added +1 Module Support
* Added pluge pattern to SMPTE bars
* Separate Audio Channel Setup
* Calibration capture speed-up
* Improved RAW metering
* Target exposure time support (behaves like redcode now)
* Enhanced AF
Rob has done a great little Summary:
[QUOTE=Rob Anderson;1124081]This is a seriously awesome update. Someone asked earlier in the thread, so here's an 'expanded' description for each improvement found in the build.
* Updated UI
The User Interface (UI) has been enhanced. If you've got a RED TOUCH 9" LCD, you'll notice the UI components are no longer scaled up or heavily pixelated. Everything is now drawn to scale for the monitor and it's much sharper and cleaner looking all around. Buttons have been cleaned up quite a bit. It's a great improvement over the original.
* Added Pre-Record
You can enable "pre-record" to start capturing footage before you even hit record. Found in SETTINGS > RECORDING > [PRE-RECORD]. Duration can be set to 10, 20, and 30 seconds. Once enabled, the DSMC will continuously capture a scratch cache of footage, prior to you hitting record. This way, you won't miss the start of a shot by being a little slow on the trigger.
* Added Time Lapse
Found in SETTINGS > RECORDING > [MODE] > "Recording Mode" [Internal Timelapse Timer]. The default, "continuous recording" locks your recording into the normal FPS/angle parameters. With Internal Timelapse Timer enabled, you can now set a 1 frame interval to capture every X-seconds. X-seconds can be set from a minimum of 1 second up to 3,599 seconds (1 frame captured every 60 minutes).
You can also set the recording to end at a predefined frame limit. SETTINGS > RECORDING > [X] Limit Recording To: [selectable].
Found in SETTINGS > RECORDING > [MODE] > "Recording Mode" [Speed Ramp mode]. Next, set the target FPS and amount of time you want to allow the speed ramp to adjust. For example, 96 FPS and 5 seconds would ramp your capture speed from whatever you set the start at (24 FPS, for example) and in 5 seconds, the FPS speed will increase from 24 FPS to 96 FPS leading to a very smooth transition of FPS being captured.
Next, you'll want to assign a key to trigger the ramp. SETTINGS > SETUP > KEYS > [Key Mapping] or [Soft Keys]. You'll want to assign the key "Record: Start Speed Ramp" to either a hard key or a screen/touch 'soft' key (or both for convenience).
You can only ramp speed once. So if you default your FPS to 24 and ramp up to 96, once you hit record, you'll be capturing at 24 FPS. Now trigger the "Record: Start Speed Ramp" key and, at the interval you defined, FPS will increase to 96. It will then stay at 96 FPS until you stop recording.
Found in SETTINGS > DISPLAY > MONITOR CONTROL > and then [X] Flip/Mirror UI and [X] Flip Video. With both enabled, you'll flip the UI and the video upside down on your monitors. This doesn't change how your footage is captured -- only how you interface with your footage on camera via monitors. This is useful for more unusual mounting positions of the touch screens, including a horizontal folded out option that treats the screen more like a flat touch surface.
See above.
Found in SETTINGS > DISPLAY > MONITOR CONTROL > OVERLAY. User-definable UI overlays you can figure to personalize and move things around. There are also presets installed including options for 3D controls. Overlays can be stored on the camera or transferred to SSD and stored on computers or copied from camera-to-camera. You can create overlays directly within the DSMC UI.
Found in POWER > [POWER SAVE]. Three settings you can define; (1) Low Power Preview, (2) Sleep, (3) Auto Shutdown for when the camera is not in use.
1:1 pixel zoom for concise focusing.
Greater support for LCD monitoring. Found in SETTINGS > DISPLAY > MONITOR CONTROL and then "Frequency" dependencies for each monitoring option (Brain LCD, Brain EVF, etc).
Found in SETTINGS > MAINTENANCE > CALIBRATION > "Current CalMap" drop-down. Default is factory and this can now be changed to "user HS". User-selectable calibration maps for camera settings.
Self-explanatory. If calibrations are out-of-sync with expected exposure and temperature maps, you'll get a warning to adjust calibration.
Found in SETTINGS > DISPLAY > TEST SIGNALS > [LUMA RAMP]. A luma ramp (black to white pattern) will display.
Found in AUDIO. Additional tools for adjusting the Pro IO (if connected) and monitoring audio mix.
Trent posted an explanation of this here:
http://www.reduser.net/forum/showthr...=1#post1124041
To enable long exposures:
- Goto: Settings->Recording->Frame Processing
- Set Frame Processing Mode to "Frame Summing"
- Chose the number of Frames to Process (this will act as a divider on the framerate).
For example, if you chose 16 frames in summing mode, then you can set your framerate down to 1/16.15FPS (or 16.15 seconds per frame). Your exposure time still needs to be set. Or more precisely, you still have control over your exposure time for each frame that is summed to create the long exposure. Choosing a full exposure is like a traditional long exposure. However you can chose a smaller exposure time for effect if you like. In this mode you are previewing before the summing so expose accordingly. As soon as you hit record you will see the summed exposure.
Found in SETTINGS > RECORDING > [FRAME PROCESSING]. You can now set the drop-down from "No Frame Processing" to "Frame Summing" (long exposures, see above) or "Frame Averaging" (noise reduction). Still testing this and looking forward to posting results. Sounds awesome.
Shutdown and reboot DSMC and REDmote and both will now auto-pair, once previously synchronized.
Jarred has previously posted the +1 Module will now ship in february. This module will allow you to run two RED Touch monitors (a 9" and a 5" for example), or a Touch with an EVF, etc.
Found in SETTINGS > DISPLAY > TEST SIGNALS.
Found in AUDIO.
Black calibration takes approximately 10-12 minutes now. An improvement of around 60%. Keep in mind, temperatures cause things to drift and re-calibration is required.
Found in SETTINGS > DISPLAY > TOOLS > then "RAW" button. Picture looks cleaner but not sure what else has changed here.
