Click here to go to the first RED TEAM post in this thread.   Thread: Red Dragon Info and Data Sheets
Page 11 of 21 FirstFirst ... 789101112131415 ... LastLast
Results 101 to 110 of 210
  1. #101
    Quote Originally Posted by Kemalettin Sert View Post
    Hey Phil can you add ANA mode specs on Format Key 2013 chart.
    I will when the final Anamorphic Mode(s) are in the Epic Dragon build.
    phfx.com IMDB
    PHFX | tools
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Kemalettin Sert's Avatar
    May 2009
    Los Angeles CA
    Thank you!
    There has been much confusion regarding how Epic Dragon handles anamorphic support. I wanted to update this with a bit of a key to understanding it for those who choose to shoot anamorphic.
    Dragon Basic Anamorphic Shooting Notes
    Currently Dragon has support for 1.3X and 2X anamorphic modes.
    If you're using 2X anamorphic lenses you will likely desire the 4:3 or 5:4 aspect ratios under the 4K resolution. These aspect ratios are not supported at 6K, 5.5K, 5K, or 4.5K. However, do not let that confuse you, you will get what you are after under the 4K resolution mode using these aspect ratios.
    For instance, 4K 5:4 equals 3840x3072 and unsqueezed you produce a 7680x3072 image with a 2.50:1 aspect ratio. You will notice that this is using close to the full height of the sensor.
    If using 1.3X anamorphic lenses you may want to explore the 3:2 aspect ratios found at 4.5K and lower resolutions, which produce an aspect ratio of 1.95:1.
    It's a bit different than the "old way", however this way is now more aspect ratio and resolution width based. Which makes a bit of sense.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Just adding an example image for those shooting anamorphic.
    Here's the typical 4K 2X ANA setting using the 5:4 aspect ratio.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Senior Member harjotsingh's Avatar
    San Francisco Ca
    Thanks Phil!
    Is it possible in the Dragon menu to create a custom recorded aspect ratio? For example it would be useful to me to record 2809 x 3160 (0.89:1 aspect ratio), with 2x anamorphic lenses, to give a final desqueezed output aspect ratio of 1.78:1
    Richard Bradbury
    Focus Puller
    London, UK
    Quote Originally Posted by Richard Bradbury View Post
    Currently not, but it was hinted that we might see in a future firmware update "custom resolution" support.
    Fingers crossed. I have my eyes on one particular format that I think would be exceptionally useful for productions that are destined for widescreen and 16x9 with an additional focus on lens coverage.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Many thanks Phil.
    Richard Bradbury
    Focus Puller
    London, UK
    May 2009
    Los Angeles CA
    Whats the sensor sizes on Ana modes*
    Senior Member Mikael Lubtchansky's Avatar
    Jul 2007
    France
    Phil your first post says there is no Carbon upgrade path... Was true at the time but the option now exists so maybe you should update it...
    Link : http://www.reduser.net/forum/showthr...=1#post1299222
    Hard work to keep track of everything RED and maintain all published info up to date... Thanks again for the amount of time you devote to this...
    Another good example of Jim's "Everything subject to change... Count on it"
    foolcat : HTML / PDF visual reports for OS X
    foolcontrol : RED camera control for OS X
    foolcontrol : RED camera control for iOS
    foolcolor.net staying hungry, staying foolish twitter vimeo facebook instagram
