Thread: Assigning Redcine to Spaces?
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1 Assigning Redcine to Spaces?
    Is there any way to switch in and out of Redcine with other applications? I tried assigning it a "Space" in OS X 10.5.2.
    Kelly H.
    Quote Originally Posted by AIOT View Post
    Kelly H.
    F11.
    Lucas
    Quote Originally Posted by luki View Post
    F11.
    Lucas
    We tried that originally. It works on our laptop, but not on the tower. Same OS on both. Can't figure it out.
  4. #4 Fixed it!!!
    On the laptop it was F11. On the 8 Proc it was fn F11. Go figure...
    Senior Member Alexis Hanawalt's Avatar
    Mar 2007
    Los Angeles, CA
    There's a preferences pane that lets you assign these shortcuts - be wary of Spaces, though... I get buggy issues when I use it with FCP (although nothing bad enough that I don't still use it.)
    Alexis Hanawalt
    Bolster Camera, Inc.
    www.bolstercamera.com
    Using REDCINE with Spaces will muck up things here. I still have REDCINE go screwy or just crash when trying to run other applications at the same time. No direct offense intended, but this stability issue needs some serious attention because it's inexcusable. I don't know what's causing it, if it's a memory protection issue or if it's a GPU issue, etc.. Same deal whether I run it on a Macbook Pro w/ATI GPU or a Mac Pro w/nVidia... Spaces usually causes REDCINE to self destruct. A dual monitor setup is a little better... Sometimes I can work in another application on my primary display while REDCINE is on the other, but I would never attempt if I was processing anything important.
    Oh, and let's take a look at the multithreading code too... It sure can saturate all 8 CPUs on my Mac Pro at 70% or better when processing. But how come the performance increase over locking it to 4 cores is only about 5%? Something isn't right...
    - Jeff Kilgroe
    I've suddenly had RedCine pop up on my right monitor instead of my left .... I just wish I could get it back to the left. Any ideas how?
    Sorry if this is obvious, but I believe there's an OS setting for letting the function keys pass straight through, vs. having to hit Fn. I noticed this first on one of those new metal keyboards.
    Senior Member Shawn Booth's Avatar
    Honolulu. HI
    you can also just try the "Command+Tab" technique that I love so much...
    #994 - Cassavetes
    Quote Originally Posted by kowboy View Post
    Does that work on your machine? Nothing here, only F11. I wished you could set your own key preferences or there was a button to hide RedCine, F11 is just a weird key.
