REDUSER.net
Go Back   REDUSER.net > Shooting RED > Audio
Reply
Thread Tools Display Modes
Old 03-31-2008, 09:31 PM   #1
Stephen Pruitt
Stephen Pruitt's Avatar
Default Has there been any resolution to the 744T/RED synchronization issue?
I just got a 744T and now have read that there is an approximately two frame synch issue between the RED and the 744T. However, the last post on this issues appears to have been over a month ago.
Has there been a solution to this problem??? This is a pretty big deal to me.
Stephen
__________________
RED One M-X "Lewis" (#791)
www.NVR2L8.com
www.DuhMagazine.com
First feature film, "Works in Progress," out on DVD in November 2010.
Second feature film, "Terminal," now in pre-production and scheduled to begin production September 2010.
Stephen Pruitt is online now   Reply With Quote
Old 03-31-2008, 10:32 PM   #2
C.H.Haskell
C.H.Haskell's Avatar
Default
talking about the sound device unit? I was unaware of this issue myself but also curious if its been sorted.
__________________
C.H. Haskell, ICG
Director.DP.Writer
haskellfilms.com
RED EPIC#TBA VIEW REEL
C.H.Haskell is offline   Reply With Quote
Old 04-01-2008, 06:53 AM   #3
Stephen Pruitt
Default
Yes, the SD744T. . .
Thanks.
Stephen
__________________
www.NVR2L8.com
www.DuhMagazine.com
Old 04-01-2008, 10:09 AM   #4
Steve Sherrick
Steve Sherrick's Avatar
Default
Stephen, Have you tested it yet with the most recent build? I haven't had a chance to do that test yet. But I will soon.
Clapboard is the easiest way to test.
__________________
Steve Sherrick
Chief Collaborator
Obscure Knowledge Productions
STEVESHERRICK.COM
Local 600 DIT/Operator
Steve Sherrick is online now   Reply With Quote
Old 04-01-2008, 11:04 AM   #5
Stephen Pruitt
Default
Hi there, Steve. . .
I haven't got a time code clapboard. . . and I haven't even turned my 744T on yet. I could be awhile before I get around to that. . . you pros will have to answer this one.
Stephen
__________________
www.NVR2L8.com
www.DuhMagazine.com
Old 04-01-2008, 11:11 AM   #6
Mark L. Pederson
OffHollywood
Mark L. Pederson's Avatar
Send a message via AIM to Mark L. Pederson
Default
our last tests at GOTHAM SOUND indicated that we are frame accurate on Sound Devices and Metacorder BWF files - camera in jam sync
however, we are seeing 2 frame offset in SINGLE SYSTEM mode - audio coming in LINE from mixers - ????
Build 15 - anybody run SYNC tests in single system mode with build 15 using LINE from mixer??
__________________
Mark L. Pederson
Offhollywood Get the BUZZ
http://twitter.com/offhollywood
Mark L. Pederson is online now   Reply With Quote
Old 04-01-2008, 11:22 AM   #7
Steve Sherrick
Default
Will do tests later on today
__________________
Steve Sherrick
Chief Collaborator
STEVESHERRICK.COM
Old 04-01-2008, 11:30 AM   #8
Mark L. Pederson
OffHollywood
Default
Quote:
Thanks Steve - hit my email if you post results -
__________________
Mark L. Pederson
Old 04-01-2008, 01:49 PM   #9
Stuart English
Red Team
Stuart English's Avatar
Default Sync - Audio and Timecode to Video
I think audio is correct to maybe a fraction late within the video frame timing on Mic input using Build 15 v2.1.7 (tested with QT proxy movies FCP) See attached JPEGS.
But timecode sync is perfect with external slate (tested with Ambient ACD 301 and QuicKTime Player, RED ALERT ! and FCP
Let me know if you agree, and what you find out about line input audio sync.
(Note: In the images below the slate timecode update freezes at 22:17 so there is an apparent 1 frame offset, but its not really there)
__________________
Workflow Wizard
Stuart English is online now   Reply With Quote
Old 04-01-2008, 08:53 PM   #10
Stephen Pruitt
Default
How on earth could audio be that late on a line in? That's really, really strange. Surely those AD converters aren't that slow on the uptake, are they? Wow. . . this is pretty disappointing.
Stephen
__________________
www.NVR2L8.com
www.DuhMagazine.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
