#1 |
Quick question.
Can RED effectively go "shutterless"? I have a project that would benefit from this. How about frame addition? J.
__________________
"Eternal salvation or triple your money back!" |
#2 |
Red Team
At 24fps that's essentially what 1/24th is. Until we have the flux capacitor upgrade board...
#3 |
Ok so no "shutter off" option.
It "is" off technically Thanks Deanan. Hopefully flux cap board will incorporate Memristors for instant start up!
__________________
#4 |
Moderator
Just a theoretical question: Couldn't it be possible to get a 720 degree shutter by adding half of the previous and next frame's exposure?
Would that be feasible? I am trying to figure out in my head what it would look like in motion.
__________________
#5 | |
Quote:
I do think it would be cool to have longer shutter options for timelaps stuff though. |
#6 |
I want the shutter to be open way longer than 1/24. Like anywhere from 1/2 sec to 10 sec. Now that would be great.
#7 |
I bet they can make it can happen in camera - similar to the EX1's slow shutter frame accumulation mode, but the result is very stacatto for anything but timelapse work. It is, however, very cool for timelapses! Streaky cars, star lapses, etc.
#8 |
But Deanan, if you're doing timelapse shots, can you use a longer shutter than 1/24th ?
Like 1 second for example ? Will that be possible in the future ? Nils. |
#9 | |
Moderator
Quote:
So, frame 1 would be underexposed, frame 2 would consist of 50% from frame 1, 100% from frame 2 and 50% from frame 3 - once that is ready. Frame 3 again would take 50% from the buffered frame 2, 100% from frame 3 and 50% from frame 4. Now Frame 2 could be written to the CF. And so on. Once you push the stop button, one last frame is written to the CF. Or like this: Buffer 1: Frame 1 Buffer 2: Frame 2 Buffer 3: Frame 3 Write Frame 1 with 50% Buffer 1, 100% Buffer 2, 50% Buffer 3 Buffer 1: Frame 4 Write Frame 2 with 50% Buffer 2, 100% Buffer 3, 50% Buffer 1 Buffer 2: Frame 5 Write Frame 3 with 50% Buffer 3, 100% Buffer 1, 50% Buffer 2 ... ... ... Buffer 1: Frame 4783 Buffer 2: Frame 4784 Buffer 3: Frame 4785 -push stop- Write frame 4783 with 50% Buffer 1, 100% Buffer 2, 50% Buffer 3 Buffer 1: Frame 4786 Write Frame 4784 with 50% Buffer 2, 100% Buffer 3, 50% Buffer 1 As said, this is all theoretical. (But shouldn't it be possible to try this out when shooting with 48 frames, and then adding them in post into a 24 frame project?) But I think it might be worth exploring; maybe a way to go beyond the ISO 1000/3200 - or maybe just to get a new "cool" effect for pop promos.
__________________
#10 | |
Quote:
Right now you can do a 33%+33%+33% with my FUSE option of the Kinema Insert command, if you duplicate the input frame set and offset starting one group on frame 1, another on 2, and another on 3 (making up the lost frames at the end with dups). Then tell the FUSE command there are 3 tricolor frames in the group to fuse. You may need to use a macro to do the file shuffling and renaming to get the input set right. You might be able to shift the gamma of the three sets of the same files to give the "middle" file more of a share of the output. If someone wants to try this let me know by PM. |
| Thread Tools | |
| Display Modes | |
