REDUSER.net
Go Back   REDUSER.net > RED One Camera > Accessories for RED ONE
Reply
Thread Tools Display Modes
Old 10-21-2008, 01:09 PM   #1
Jeffrey Hamlin
Jeffrey Hamlin's Avatar
Default Panasonic BT-LH1760 17" Production Monitor
All...
I just received word that my RED is ready to ship. To that end, I have purchased the RED EVF but not the LCD display monitor. For purposes of pulling focus and the like, does anyone know if the Panasonic BT-LH1760 17" Color LCD Production Monitor can be easily hooked up and run as a full display?
To alleviate any concerns, I am not under the illusion that the monitor will move with the camera in any type of hand-held setup. I am thinking of using the 17' monitor for dolly shots and lock downs. I have room on the dolly to mount the monitor in close proximity to the camera/focus puller.
Any input would be great.
Thanks in advance.
Jeffrey Hamlin is offline   Reply With Quote
Old 10-21-2008, 01:14 PM   #2
Patrick Tresch
Patrick Tresch's Avatar
Default
It's ok, I've used it several times with the HD-SDI input. But I don't think it's the best solution for your money out there.
As it's only for preview it's ok but you'll have better solutions for color/luma rendition and for resolution (focus).
Patrick
Patrick Tresch is offline   Reply With Quote
Old 10-21-2008, 05:10 PM   #3
Dan Carew
Default
Hi Patrick,
What would you recommend instead?
thanks!
Dan
__________________
Dan Carew
Hong Kong
Indie2zero blog
Kanda River Limited
Dan Carew is online now   Reply With Quote
Old 10-22-2008, 04:34 AM   #4
Patrick Tresch
Default
I would try to investigate in the HDMI port of the camera (is this 1080 or 720p?) and look after an 24' LCD. I didn't google it, nor researched on this forum...
There is some homework to do :-)
Patrick
Old 10-22-2008, 11:21 AM   #5
Wil Klassen
Wil Klassen's Avatar
Default
We've stuck by the Panny 17" off of HD-SDI and never had a problem (as a client monitor). I have read a thread about the HDMI freezing the RED. For a select few its fine and there is no prob, but it seems more have the camera freezing off HDMI than not.
http://www.reduser.net/forum/showthr...highlight=HDMI
Something to investigate before you invest. Sorry I can't much give a recommendation, just a tip of the hat to the Panny.
Wil Klassen is offline   Reply With Quote
Old 10-22-2008, 12:03 PM   #6
Steve Freebairn
Default
The 17 is a great monitor to get, make sure you get the newer one though, the older 17 inch doesn't like the 1080 playback from the camera.
__________________
IATSE Local 600 DIT
www.ipaddailies.com/
Steve Freebairn is offline   Reply With Quote
Old 10-24-2008, 06:51 PM   #7
Jeffrey Hamlin
Default
Thanks guys!
Old 10-24-2008, 07:51 PM   #8
C.H.Haskell
C.H.Haskell's Avatar
Default
Yes this is a great monitor, it goes on every job with me...packs up well, built to travel, and sits on my desktop in home studio for 1080 playback off kona card.
My monitor will not work with 1080 SDI from RED...just 720, looks sharp as a tack though. Is this an issue with the older version...any way to solve this? bummer.
__________________
C.H. Haskell, ICG
Director.DP.Writer
haskellfilms.com
RED EPIC#TBA VIEW REEL
C.H.Haskell is offline   Reply With Quote
Old 10-24-2008, 10:32 PM   #9
Stuart English
Red Team
Stuart English's Avatar
Default Monitor
It may be a true Progressive v's PsF signal issue.
It is a SMPTE spec signal from the camera and I plug into other Panasonic and JVC monitors frequently.
__________________
Workflow Wizard
Stuart English is online now   Reply With Quote
Old 10-24-2008, 10:44 PM   #10
T. Glen Phelps
T. Glen Phelps's Avatar
Default
The 1760 works fine. The only catch (if you want to call it that) is that you can't get the menus over HD-SDI.
__________________
T. Glen Phelps
T. Glen Phelps is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
