REDUSER.net
Go Back   REDUSER.net > RED One Camera > Accessories for RED ONE
Reply
Thread Tools Display Modes
Old 11-21-2008, 02:14 PM   #1
joshtimonen
Junior Member
Default 7" LCD / Red Drive dimensions?
Hi,
I just received my Red One with most of the accessories, but I'm still waiting on the 7" LCD, Red Drive and 18-85 lens. I'm going to be cutting foam for my Pelican 1650 case, and was curious if someone could give me the rough dimensions of the Red Drive and 7" LCD screen, so I leave enough room in the case for them. I'm not going to cut holes for them at this point, just set aside enough space to accommodate them. The site's dimensions on the 18-85 lens (142 mm diameter at the large end and 11" long) should be sufficient. Is there a page with this dimension information already?
Thanks,
Josh
joshtimonen is offline   Reply With Quote
Old 11-21-2008, 02:36 PM   #2
Curran Giddens
Curran Giddens's Avatar
Default
7" LCD:
7" wide x 4 3/8" high x 1 1/16" deep (not including the LEMO connector which sticks out about another 1/2"
RED Drive:
6" wide x 3 3/8" high x 1 1/2" deep
__________________
www.SolarSystemStudio.com
Rocket™-powered Mac Pro DIT cart + HP DreamColor, Arri MB20-II, OConnor CFF-1
Curran Giddens is online now   Reply With Quote
Old 11-21-2008, 02:37 PM   #3
joshtimonen
Junior Member
Default
Perfect, thanks!
Josh
Old 07-16-2009, 05:13 AM   #4
Josele Bernabe
Junior Member
Default
Thanks, in metric sistem shall be someting like:
15'5 cm
9 cm
4 cm
It is a little less than that, but it is more easy to calculate this way, at least for me.
Josele Bernabe is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
