REDUSER.net
Go Back   REDUSER.net > RED One Camera > RED Workflow > Avid Workflow
Reply
Thread Tools Display Modes
Old 01-22-2009, 09:08 AM   #1
scotty
Junior Member
Default Blocky Blacks on DnxHD output
Has anyone else had a problem with very blocky / posterised blacks on DnxHD QTs? Having offlined now trying to render footage for online on Symphony Nitris. QTs however have these very blocky / posterised blacks when viewed in QT player and once imported to Avid.
Working on a 1080 25p project, generating 185X QTs from 2:1 4k footage, same problem is evident whether using Redcine / Red Alert / Monkey Extract.
Have just upgraded to Red Alert 3.60 and have the latest Avid codecs.
Looks like the files aren't really 10 bit. A colleague suggested that Avid QTs are only 8 bit even when selecting the 10 bit option?
TIFFs look fine in QT player and import into Avid Symphony Nitris fine as 185X, but would rather use QTs if possible.
regards
Brian
scotty is offline   Reply With Quote
Old 01-22-2009, 12:01 PM   #2
MichaelP
MichaelP's Avatar
Default
Select 185x as source when importing the QT's. If it does not say "fast import" then it is not 10bit. There has been a thread here with this issue when created from REDCINE. I have no issues when creating DNxHD 10 bit from REDrushes.
Michael
MichaelP is online now   Reply With Quote
Old 01-23-2009, 05:35 AM   #3
scotty
Junior Member
Default
Michael
Thanks for the reply. Yes files do fast import when 185x is selected so the Symphony thinks they are 10 bit.
I thought I'd post an image to show the problem better.
Here's a section of the shot I noticed the problem on.
If I export a TIFF and increase the gamma to make the blacks much more visible I get this :
If I export a DnxHD 185X QT and increase the gamma by an identical amount I get this :
These stills are representative of the effect I see whether viewing the file in QT on the Mac Pro, or once imported to Symphony Nitris.
What's really interesting is that if I use the eyedropper in Photoshop on the TIFF file I get (in the black sleeve area) figures like 16/17/17, 18/18/19 etc. but on the DnxHD QT I get figures like 16/16/16 or 17/17/17, i.e. there is never any difference between the colour channels.
Does the DnxHD codec reduce saturation near black?
Any other ideas what's going on?
regards
Brian
Old 01-23-2009, 06:16 AM   #4
Yean Loon
Default
I had the same problem...couldn't find a solution
Yean Loon is offline   Reply With Quote
Old 01-23-2009, 08:32 AM   #5
scotty
Junior Member
Default
Quote:
Thanks for the response anyway, good to know it's not just me . . .
regards
Brian
Old 01-24-2009, 08:18 PM   #6
MichaelP
MichaelP's Avatar
Default
Using a 23.976 R3D file out of REDCINE into DNxHD, I cannot get a "Fast Import" at all. Perhaps 1080p/25 is different. QuickTime Info shows it as a DNxHD file, but the Media Composer does not see it as a 10 bit file and 175x (23.976fps). Interestingly enough none of the resolutions settings will do a fast import. The same R3D file via REDrushes as 175x import with the "Fast Import" words in the import window after clicking OK.
I will try a 1080p/25 file to see if there is a difference in getting the "Fast Import" words to display during the import.
Michael
Old 02-06-2009, 09:15 AM   #7
Miguel "Macgregor" De Olaso
Miguel "Macgregor" De Olaso's Avatar
Send a message via MSN to Miguel "Macgregor" De Olaso Send a message via Skype™ to Miguel "Macgregor" De Olaso
Default
ANy news on this?
__________________
Works at www.macgregor.autoecstasy.com
support SIMILO project at http://bit.ly/similo2010
Miguel "Macgregor" De Olaso is offline   Reply With Quote
Old 02-06-2009, 12:49 PM   #8
MichaelP
MichaelP's Avatar
Default
The issue is that the wrong ID is being applied to the QT wrapped DNxHD file - all files are labelled at 1080o/50 regardless of what they truly are. We are working with Assimilate to resolve this problem.
Michael
Old 02-09-2009, 09:19 AM   #9
scotty
Junior Member
Default
Michael
Thanks for this. Any workround at the moment e.g. modify QTs with something like Apple's Dumpster?
regards
Brian
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
