#1 |
I have a job coming up where we will be shooting all day every day for a month, editing simultaneously. We will be cutting with _H proxies, as we will have no time at all to convert to Pro Res.
I'm new to the Color world, and I'd love to hear people's experiences sending Proxy edits from FCP to Color. How well does this work? Is there any way of knowing how soon the bugs will get worked out? I really don't want to have to use Crimson/Monkey at the end to convert my Proxy sequence to ProRes before I can send to Color.. any advice/experiences/horror stories greatly appreciated. |
#2 |
Zak,
Everything is pretty stable, the only issues I have are when there are long R3D files, the ones where there are more than one R3D for the same clip... Color doesn't like to load those files for some reason. The fix for me has been outputting a DPX out of RA. I cant get it to generate a new proxy that color will open. Hope this helps.
__________________
Nathan Garofalos |
#3 |
thats a big problem as 90% of my shots have more than one R3D =[
#4 |
Thats not good at all :-( FCP will load the clips just fine, but when you send to color, you'll have issues. I wish I knew of a fix for you...
__________________
Nathan Garofalos |
#5 |
If you have many spanned clips, you should rather use one of the workflows from the whitepaper.
__________________
Regards, Uli My Red is called Vertov after a Russian avantgarde filmmaker, a pioneer in modern cinematography, a true revolutionary who later suffered under Stalin's bureaucracy. |
#6 |
REDuser Sponsor
Also, ther are other threads dealing with workarounds, but using an EDL instead of sending to color will resolve this issue. Also check:
http://reduser.net/forum/showthread.php?t=26474 and http://www.reduser.net/forum/archive...p/t-25641.html and http://www.reduser.net/forum/archive...p/t-25641.html
__________________
Birns and Sawyer www.birnsandsawyer.com Your Vision. Our Gear. Camera Sales and Rentals: (323) 466-8211 Lighting and Grip: (818) 766-2525 |
#7 |
So cutting with proxies and doing color correction to the proxies with color is totally cool then? all I have to do is use an EDL instead of SEND?
I don't want to have to do any "coding" or anything like those other work arounds.. |
#8 |
REDuser Sponsor
Yes, I have done it. The only problem is if you have any effects in your FCP timeline, when you send them back to FCP the effects don't get added back in. It's a bit annoying, but it can work.
__________________
#9 |
i understand where you're coming from but i don't think you'll be able to avoid something like pro-res at some point. the log and transfer is much faster than converting to pro-res in something like redcine or even quicktime. but what are you coming out of color with? you can just use the proxy but that will give you problems with longer r3d files like others have mentioned. but if you're sending something like a proxy in and back out of color, you're not really getting the extra bit depth that pro-res gives you so you might as well stay in fcp and just do basic correction in there and then output. but what will you output from fcp? unless you know exactly how you want you're finished/graded cut in, pro-res is kind of hard to avoid in the apple/quicktime workflow.
#10 | |
REDuser Sponsor
Quote:
__________________
| Thread Tools | |
| Display Modes | |
