REDUSER.net
Go Back   REDUSER.net > Shooting RED > Cinematography
Reply
Thread Tools Display Modes
Old 05-13-2009, 12:07 PM   #1901
Steven Caesare
Default
Quote:
Originally Posted by Policar View Post
I don't mean to butt into a thread where the questions aren't mine to answer, but this one seems pretty simple: they used a split diopter, which is basically a close-up (diopter) filter that only covers half the lens.
http://www.shutterbug.com/images/arc...403macro.9.jpg
Ah, cool. Is that common? I can't recall seeing that before.
Thanks.
-Steve <-- (who is a complete cinema outsider)
Steven Caesare is online now   Reply With Quote
Old 05-13-2009, 04:12 PM   #1902
David Mullen ASC
Moderator
David Mullen ASC's Avatar
Default
The oldest movie I've ever noticed split-diopter filters used in is "King of Kings" (1961) -- the filters seem to work particularly well with widescreen aspect ratios. But in theory, the filter is so simple in concept (a close-up diopter sawed in half) that I'm surprised I haven't seen earlier examples. The diopter part of the filter allows closer focusing than the clear area, so you set the lens focus for the clear area covering the more distant object you want to be in focus, and then you vary the strength of the diopter that covers the foreground object until it comes into focus. And you do a lot of fiddling with the camera distance, etc.
"Star Trek: The Motion Picture" has a record number of split-diopter shots -- the director wanted a deep-focus look but on 100 ASA film using anamorphic lenses in a set with projection screens, there was no way to light to a high enough level for deep focus, so they resorted to using a lot of split-diopters:
They even got fancy and used some diopters cut into special shapes, like this one which only covers the center person but is clear on each side:
And here is a diopter only covering each side but the center is clear:
__________________
David Mullen, ASC
http://www.davidmullenasc.com
David Mullen ASC is online now   Reply With Quote
Old 05-13-2009, 04:19 PM   #1903
David Mullen ASC
Moderator
Default
An alternate approach to get a fake deep focus effect is to use a tilt-focus lens, which allows the plane of focus to fall on a receding diagonal plane rather than a flat distance. So one end of the frame is basically at minimum focus and the other end is at infinity, then you try and line up the subjects so that they fall into this receding diagonal plane. You can also adjust the degree of tilt to match the objects.
You can see a tilt-focus lens being used here in "Remains of the Day":
__________________
David Mullen, ASC
Old 05-14-2009, 07:00 AM   #1904
Steven Caesare
Default
Interesting... I just re-watched all the original ST movies (with my son to fill him in on the ST universe prior to the new movie), and didn't notice the abrupt transtion from out-of-focus to in-focus background that I saw in Andremeda Strain, despite it being in hi-def also.
Thanks for the explanation and examples.
-Steve
Old 05-14-2009, 07:17 AM   #1905
Roberto Lequeux
Roberto Lequeux's Avatar
Default
David, I really like the idea of using the tilt-focus lenses like that! I guess it could help bring out a sense of sadness/confusion/clouded-judgment etc to the person who has the bokeh behind them... and for shots where the actor isn't traveling through the frame it should be simple or at least straight forward set up. Are there there are solutions or lenses with PL mounts so you don't have to change mounts mid-day for one setup?
EDIT: Oops... found them already. :)
It seems Cinequipt has some of the Arri and Century flavor in their stock. http://www.cinequipt.com/rental_cata...2&tid=2&sid=86
Have you used either of them before? I am thinking something like the 24mm would suffice for two or three CUs like the ones you posted from "Remains of the Day".
__________________
Writer - Director
Roberto Lequeux is offline   Reply With Quote
Old 05-14-2009, 08:39 AM   #1906
David Mullen ASC
Moderator
Default
Quote:
Same director & DP -- Robert Wise and Richard Kline -- for both "Star Trek: The Motion Picture" and "The Andromeda Strain." The first trek is full of split-diopter shots, I'd guess half the non-efx footage has it somewhere.
The rest of the Trek films don't use them much except for a few shots in "Star Trek V":
__________________
David Mullen, ASC
Old 05-14-2009, 08:50 AM   #1907
David Mullen ASC
Moderator
Default
There are tilt-focus lenses made -- usually a 24mm, 45mm, and 90mm, like ARRI's:
http://www.arri.de/camera/lenses/35_...us_lenses.html
And there are shift-tilt mounts made like this one:
http://www.arri.de/camera/lenses/35_...lt_system.html
The tilt-focus lenses have less range of adjustment but are simpler and faster to use.
I find that the 45mm one is the most common one to use. Often 24mm photography already has enough depth of field and the 90mm version just looks too weird to slant because of the more telephoto view. I think those shots from "Remains of the Day" were done with the 45mm. Being that close with a 24mm would look more like an Orson Welles movie.
But you can see a lot of use of the 24mm slant-focus lens in the HBO series "Six Feet Under".
I used the 45mm slant-focus for two shots in HBO's "Big Love":
If you are using them to get a deep focus effect, it helps to also stop down the lens as well, the more the better -- the first example above was shot outside so I was also able to stop down to like f/11 or so. The second one was shot at f/4. You can see on the second one why getting in close with a 45mm is about as wide-angle as you'd want to be a lot of time, unless you like distortion on faces.
Split-diopter filters, on the other hand, don't benefit from stopping down because then the edge of the split glass comes too much into focus -- you need it to be a blurry edge.
__________________
David Mullen, ASC
Old 05-14-2009, 09:15 AM   #1908
Steven Caesare
Default
Quote:
I hadn't realized that... they must be fans of that technique.
Well, it actually figures I didn't notice... ST:The Motion Picture was the one we actually didn't watch all of because my kids fell asleep and we moved on to #2 because they thought #1 was a bit slow.... I guess I'll go finish it and keep an eye out.
Thanks again David.
Old 05-14-2009, 09:42 AM   #1909
Roberto Lequeux
Default
Ok, yea, I was worried about being too close with a wide angle. The 45mm sounds great, but I guess the DP would take a closer look at the location. One of these moments would be in a small room while the rest happen outside, and in daylight. I hope we can find a bigger room or a way to get enough small HMIs or whatever may be necessary for stopping down as necessary in there.
I think I like was done with Anthony H. in the second shot, where the out of focus area isn't all around him but just behind him.
I really like the way you shot "Barbara" with a shallow DoF effect while keeping "Margene" in focus, but I think I may like the idea of shooting the actor from the side so as to give more of a visual representation of what is ahead of the actor and what is behind, where they are coming from and where they are headed.
I guess I might be interpreting the effect as shot from the side a bit more an a look at their internal struggle from more of a voyeuristic perspective, while you gave more of a personal feel to your shot.
__________________
Writer - Director
Old 05-14-2009, 05:57 PM   #1910
Robb Cox
Junior Member
Default
Hi David, (and anyone else that would like to chime in) I have a question about lighting and framerates and in particular about lighting for music videos but first a little about what I am doing.. I have come from a mostly stills background and have started shooting a couple of music videos recently. I am using a mixture of tungsten and kino lighting and also natural lighting where I can. At the moment I am shooting with a Sony EX3 with a Letus using Canon FD lenses. To get the 'dreamy' look I am often overcranking in camera. I recently shot a short epk sequence where I had the artist lipsync over a playback track that was playing 20pc faster so I overcranked in camera from 25fps to 30fps (in Australia we have 50hz power), problem was the footage now has a gentle flicker to it. I understand that the 30fps overcrank caused this even though I was using a 1/50 shutterspeed etc. I have seen the panavision recommended framerates etc for PAL and NTSC countries but there are alot of very odd numbers that I personally cant achieve with the EX3.
My main questions are, can the RED camera overcrank in these odd framerates (ie 30.333 fps) or when cinematographers are shooting music videos (not on film) and want that dreamy overcranked look do they speed up the playback music but slow the footage down in post with something like Twixtor? I understand that this isnt an issue if you keep to the safe numbers like 25fps or 50fps but having an artist lipsync back at 2x the speed of a song is often impossible.
Thanks so much for participating in this forum and sharing your wealth of knowledge.
Cheers
Robb Cox is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
