REDUSER.net
Go Back   REDUSER.net > Shooting RED > Cinematography
Reply
Thread Tools Display Modes
Old 05-02-2009, 07:07 AM   #1
Marco Graziaplena
Default Shooting ext day and filtering
Hi
when I shot ext day I use polarizer and nd to set the iso to more or less 20 asa. Sometimes I add a UV in case of backlight and flare, to lower the red color. This means you often got 3 filters in front of the lens. I'd rather avoid lowering iso on the camera to bypass the problem. I never tried changing shutter speed cause I'm afraid of the result...
Any suggestion
__________________
Marco Graziaplena
www.marcograziaplena.com
Marco Graziaplena is offline   Reply With Quote
Old 05-02-2009, 07:18 AM   #2
Martin Weiss
Moderator
Martin Weiss's Avatar
Default
Maybe I misunderstood your question, but why would you set the ASA to 20? That sounds very low. I'd use a heavy ND with a hot mirror. A polarizer on top should give you an extra 2 or 2 1/2 stops of filtration. If you do not need the polarizer for effect, you could get a even stronger ND filter.
If your subject does not have lots of movement (for example landscape), you will also get good results with a small shutter angle. Have done it many times when there was no ND at hand. As always: test to see what pleases you.
__________________
Martin Weiss is online now   Reply With Quote
Old 05-02-2009, 08:11 AM   #3
Marco Graziaplena
Default
Hi Martin
I set my lightmeter to 20 (more or less it depends on conditions) to have a t stop around 5.6 leaving 320 iso on the camera
__________________
Marco Graziaplena
Old 05-04-2009, 09:51 PM   #4
Ryan Sims
Ryan Sims's Avatar
Default 20 What?
Quote:
Originally Posted by Marco Graziaplena View Post
set the iso to more or less 20 asa....
Okay, ISO and ASA are the same. The camera's ISO/ASA setting is 320. What is 20 on the light meter? Shouldn't it be 320 as well.
Ryan Sims is online now   Reply With Quote
Old 05-04-2009, 10:25 PM   #5
Cail Young
Default
He's doing filter factor on the meter by setting it to 4 stops (if my maths is right) under the camera's rating. If you've got ND1.2 in the mattebox, then it makes perfect sense.
__________________
Cail Young
RED/Post/Workflow
Inspiration Studios, Melbourne, Australia
Cail Young is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
