REDUSER.net
Go Back   REDUSER.net > Everything Else > Off Topic
Reply
Thread Tools Display Modes
Old 08-15-2009, 05:41 PM   #1
Andrew Walker
Andrew Walker's Avatar
Default 5D2 vs. Scarlet...Size Wise
Here are some side by sides I shot of my 5D2 and the Scarlet mockup at the Local 695 Red Event. They are pretty close in size except the RPP on the Scarlet was way bigger than my 35mm Zeiss ZF.
__________________
RED MX #127 for hire.
http://599productions.com
Andrew Walker is offline   Reply With Quote
Old 08-15-2009, 05:42 PM   #2
Matt Gottshalk
Matt Gottshalk's Avatar
Default
Very cool.
__________________
Matt G
http://www.mcgeedigitalmedia.com
Matt Gottshalk is offline   Reply With Quote
Old 08-15-2009, 05:45 PM   #3
Justin O'Neill
Justin O'Neill's Avatar
Default
Wow, very cool to see this comparison. Thanks Andrew.
Justin O'Neill is offline   Reply With Quote
Old 08-15-2009, 06:00 PM   #4
Vince Doran
Vince Doran's Avatar
Default
If you removed the battery pack from the 5D and add a view finder to the scarlet, I would say the scarlet is 3 times bigger
__________________
Fathom Productions
Vince Doran is offline   Reply With Quote
Old 08-15-2009, 06:05 PM   #5
Imran Farouk
Imran Farouk's Avatar
Send a message via AIM to Imran Farouk
Default
Its still relatively small though for the power it carries in it...
Imran Farouk is offline   Reply With Quote
Old 08-15-2009, 10:37 PM   #6
DaveT
DaveT's Avatar
Default
If not a viewfinder, then a screen is going to make the Scarlet a lot bigger too.
Also the Scarlet has no control surface bolted to it.
That said, this is one of the most interesting posts I've seen on the new Red gear in months.
DaveT is offline   Reply With Quote
Old 08-16-2009, 12:03 AM   #7
Vince Doran
Default
Add a smaller size lens (as in physical size) and your looking at 4x bigger, think of us underwater shooters that want small camera housings
__________________
Fathom Productions
Old 08-16-2009, 12:08 AM   #8
Andrew Walker
Default
Red is coming out with a smaller viewfinder to put on the Epic and Scarlet models. Plus a smaller EVF that will be kind of like the eye piece on the 5D2, except it will be the direct view of what the sensor sees...not a mirror in front of the chip.
__________________
Old 08-16-2009, 01:09 AM   #9
Vince Doran
Default
"They are pretty close in size" maybe a visit to the optometrist might help?
__________________
Fathom Productions
Old 08-16-2009, 02:21 AM   #10
Imran Farouk
Default
smaller viewfinder?Surely though when shooting at such high quality or taking high quality stills you'd want a bigger one instead of smaller...fair enough it won't be AS compact as the 5D2 but at least you can see better...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
