#1 |
Excuse my ignorance but when I play with FLUT™, what am I seeing?
I've played with settings and I still can't tell what is going on. What's the new protocol for bringing up a light hungry shot? Adjust ISO first then FLUT™? Or vice versa?
__________________
Red 363 MX Canon PL K-35 Superspeeds cin / edi / dir www.rickdarge.com http://www.theredshooter.com/ |
#2 |
Red Team
FLUT control is a fine control adjustment of ISO.
#3 |
What are some situations that make FLUT more useful than the simple ISO adjustment? Also, how is something like (6400iso / -2.5 FLUT) differ from (125 iso / 3.8 FLUT) when they both look very similar in terms of noise pattern. I'm playing with an MX shot right now and have been racking back and forth between high ISO, low FLUT and low ISO, high FLUT and I don't know what I'm seeing yet. Is there a mathematical formula we sould be following when using both of these?
__________________
#4 | |
Red Team
Quote:
#5 |
Does the FLUT adjustment at low ISOs differ from the FLUT adjustment at higher ISOs? Does it compound in power as you move up or down or is it independent of where you set ISO?
__________________
#6 |
Moderator
FLUT adjustment seems like ASA adjustment minus the clipping. It makes me wonder if, perhaps, shooting at ASA 100 with a FLUT of 3 is better than shooting at ASA 800. Same exposure, but minus the clipping... right?
Test time... |
#7 |
So we're just affecting the midtones then?
__________________
#8 | |
Red Team
Quote:
If you're at 250 and you set flut to 1.0, you're increasing by one stop which will look the same as iso set to 500 and flut set to 0. Nope. It's exactly the same either way. |
#9 |
If it's the same then as ISO adjustment, why call it FLUT and not just ISO-2 ?
__________________
#10 |
Red Team
ISO in the new color science is based on the core of FLUT. The real magic happens in FLUT and ISO settings are like FLUT presets.
| Thread Tools | |
| Display Modes | |
