REDUSER.net
Go Back   REDUSER.net > RED One Camera > RED ONE - General > Bugs / Problems / Help!
Reply
Thread Tools Display Modes
Old 11-05-2007, 06:21 PM   #1
Greg M
Digital FX
Greg M's Avatar
Default PL Mount and data connection
In order to align the data connections on my Arri Ultra Primes the lens mounts with the focus scale facing up rather than toward the operator as it should (see attached image).
When the new PL mount is installed is it possible to re-align the data connection so the lenses will mount with the correct orientation toward the operator?
__________________
www.digitalfx.tv
dfx blog
2k - 4k di
editorial - visual fx
"There are a lot of places I like, but I like New Orleans better." - Bob Dylan
Greg M is online now   Reply With Quote
Old 11-05-2007, 06:23 PM   #2
Steve Gal
Steve Gal's Avatar
Send a message via AIM to Steve Gal
Default
I would like to see this change as well.
Steve Gal is offline   Reply With Quote
Old 11-05-2007, 06:23 PM   #3
Greg M
Digital FX
Greg M's Avatar
Default
One more question- Is the data connection actually capturing data in the current release?
I don't see any lens information in the metadata.
__________________
www.digitalfx.tv
dfx blog
2k - 4k di
Old 11-06-2007, 09:17 AM   #4
chuck colburn
Default
Most PL mounts have a slot in each of the four ears which allow four different mounting configurations. 90 degrees apart.
__________________
CHUCK
chuck colburn is offline   Reply With Quote
Old 11-06-2007, 09:29 AM   #5
Greg M
Digital FX
Greg M's Avatar
Default
Quote:
This is about the data connection, not the PL slots. Yes I can rotate the lens to the correct position in the PL mount, but if I do the Data connection on my lens does not mate the camera body.
EDIT:
I attached two more photos to better illustrate what I am asking for;
1. This is the correct orientation of the lens on the body (obviously "correct" is subjective, but it is the typical position so the operator can see the focus scale)
2. If the lens is in the position shown in the first image the data contacts are not aligned as shown in the second image.
__________________
www.digitalfx.tv
dfx blog
2k - 4k di
Old 11-06-2007, 11:11 AM   #6
Cüneyt Kaya
Cüneyt Kaya's Avatar
Default
is there any reason why it is build that way?
__________________
Kaya
All Ahead Film
Cüneyt Kaya is online now   Reply With Quote
Old 11-06-2007, 11:28 AM   #7
Sanjin Jukic
Sanjin Jukic's Avatar
Send a message via AIM to Sanjin Jukic
Default
How it is with ARRI, Moviecam, Sony, Viper... cameras?
How it is with Cooke lenses and Angenieux Lenses?
Also with RED lenses?
__________________
Sanjin Jukic - RED1 Camera Experimentalist
"There is no point in having sharp images when you've fuzzy ideas."
Jean-Luc Godard.
Dynamic range is, after all, the measurement between well saturation (photosite blowout) and noise floor.
Thom Hogan
Digital Cinema Production
Vienna-Austria
Sanjin Jukic is online now   Reply With Quote
Old 11-06-2007, 11:38 AM   #8
Greg M
Digital FX
Greg M's Avatar
Default
Quote:
Ok, did a bit more research and this is what I learned;
The Red lenses and Cooke S4i lenses have the data port dead center of the two focus scales which is why Red has the port at this position. Arri LDS lenses have the port above one of the focus scales and on the Arri camera bodies they have two data connections 90 degrees apart so you can put the lens in either position.
So the data port is in the correct place if you have Cooke or Red lenses...If you have Arri LDS you are SOL...unless Red decides to add a second connection similar to Arri.
__________________
www.digitalfx.tv
dfx blog
2k - 4k di
Old 11-06-2007, 11:44 AM   #9
Cüneyt Kaya
Default
thanks.....so gear we use really means gear we use
http://www.red.com/gear_we_use
__________________
Kaya
All Ahead Film
Old 11-06-2007, 11:57 AM   #10
chuck colburn
Default
Quote:
EDIT:
Sorry about that. I see what your talking about now. I'm not fimiliar with those lenses but most PL mounts have a slot on the lens side seating surface that mates to a pin or such on the lens itself. This keeps the mount from rotating on the lens. If these are your personal lenses perhaps you could have an additional slot cut on the back of the PL mount to align right on the RED camera.
__________________
CHUCK
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
