REDUSER.net
Go Back   REDUSER.net > RED One Camera > RED ONE - General > Bugs / Problems / Help!
Reply
Thread Tools Display Modes
Old 02-16-2008, 09:29 AM   #1
Kjetil Haugen
Kjetil Haugen's Avatar
Default LCD humming
Have been filming for a day now with build 14. Suddenly the LCD startet to beep constantly and i havnt stopped since. I remember someone mentioning this before, but thought that it was fixed right away. Downloaded build 14 yesterday.
If I reinstall 14 will this keep happening?
The camera is superb by the way!!!!!!! Well done RED team.
Kjetil Haugen is offline   Reply With Quote
Old 02-16-2008, 10:36 AM   #2
donatello b
Default
just to make sure...
Build 14 (v2.0.2) posted 2-6-08- it had a LCD noise issue ..
they posted a Build 14 (v2.0.3) on 2-7-08 that fixed the increase noise of LCD ..
i would re-download build 14 today and load it in just to be sure ...
donatello b is offline   Reply With Quote
Old 02-16-2008, 10:39 AM   #3
Nathan Garofalos
Nathan Garofalos's Avatar
Send a message via AIM to Nathan Garofalos
Default
You may want to try and re-install build 14, then if that doesn't work try build 13 and see if anything changes.
All LCD's hum, but you say yours is beeping, I don't really know what may be wrong but that may be a tentative solution.
__________________
Nathan Garofalos
Nathan Garofalos is online now   Reply With Quote
Old 02-16-2008, 10:59 AM   #4
Anthony Gratl
Default
Does anyone know why the Red LCD hums and emits high pitched noise? Maybe someone from Red could comment on this please? I'm actually somewhat concerned about buying a monitor that does this...
Anthony Gratl is offline   Reply With Quote
Old 02-16-2008, 11:26 AM   #5
Stuart English
Red Team
Stuart English's Avatar
Default Lcd
Quote:
Yes we do know the root cause of that and hence the software update. The noise level should be the same now between any build up thru Build and again with V2.0.3 Build 14... we made an error in the V2.0.1 and V2.0.2 - which were Beta builds - of Build 14.
__________________
Workflow Wizard
Stuart English is offline   Reply With Quote
Old 02-16-2008, 11:56 AM   #6
Anthony Gratl
Default
Quote:
Hi Stuart, thanks for replying. What is the root cause of the noise?
Old 02-16-2008, 12:10 PM   #7
Kjetil Haugen
Default
I do have the newest version of build 14. Upgraded yesterday as I got my camera only yesterday. At first everything was fine, then suddenly it just felt like beeping like hell. Hasn't stopped since.
Should I just reinstall 14 or do I have to downgrade to 13 and then upgrade again?
Other than that the camera rocks!
Old 02-16-2008, 12:15 PM   #8
Nathan Garofalos
Default
Try down grading to 13 and see if that works. Build 14 is still in beta build I believe. 13 is rock solid.
Then see if the beeping is gone.
__________________
Nathan Garofalos
Old 02-16-2008, 03:08 PM   #9
Kjetil Haugen
Default
I downgraded to 13 and upgraded again. Problem solved! Hope it doesn't pop again. I like build 14 with it's 3k options. Will there be a non-beta release soon or will it go straight to build 15?
Old 02-17-2008, 11:54 AM   #10
Kjetil Haugen
Default
Sooo. Problem's back. But only when adjusting the brightness on the LCD. I downgraded to 13 and then upgraded again yesterday. It beeps non-stop, except for when the LCD is at the highest brightness. Is this a known problem?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All Content Copyright Landmine Media, Inc. 2010
