Click here to go to the first RED TEAM post in this thread.   Thread: DSMC build 6.2.44 + REDCINE- X Build 39
Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 73
  1.   Click here to go to the next RED TEAM post in this thread.
  #1 DSMC build 6.2.44 + REDCINE- X Build 39
    Fire Chief Jarred Land's Avatar
    Double update for RCX and DSMC today, Enjoy :
    SIGNIFICANT CHANGES SINCE PREVIOUS BUILD v6.2.25
    * Added WEAPON MAGNESIUM support
    * Added SCARLET-W support
    * Added REDMOTE v9.5.33
    * Added Horizon to the 'Display' preset group
    * Fix 0% power level with V-Mount and Gold Mount Battery modules (WEAPON only)
    * Fix QT file crashing Resolve/Premier (WEAPON only)
    * Fix elevated audio levels with Base Expander (WEAPON only)
    * Fix boot hang with active Genlock and Auto Cal (WEAPON only)
    * Fix video stutter during Weapon playback (WEAPON only)
    * Fix Enhanced A/F notification (Weapon only)
    * Fix HDRx state in network storage mode (EPIC DRAGON/WEAPON only
    * Fix incorrect Ramp mode frame rate on startup
    * Fix Preset Create/Clone not functioning
    * Fix Switchblade/Sidekick operating mode during calibration
    * Fix blank HDRx setting on startup when enabled
    * Fix stale calibration info displayed in UI
    * Fix calibration error with active Genlock
    * Fix HD-SDI video disruption during start/stop record
    * Fix potential camera freeze using keyboard
    * Fix intermittent sync failure on startup
    * Fix sync loss when record is active
    * Fix incomplete UI dropdown lists after defaults restore
    * Fix 2K FF audio sync
    * Fix AF zone shifted to the right
    * Changed UI behavior for ACES
    * Improved Calibration Map Import notifications
    * Improved Motion Mount colorimetry
    REDCINE-X Professional Build 39 Release
    Note: RED ROCKET support requires driver 2.1.23.0 and firmware 1.1.18.0 or higher.
    Note: RED ROCKET-X support requires driver 2.1.31.0 and firmware 1.4.1.16 or higher.
    Added: Dragon 8K support.
    Added: HDR Gamma Curves: HDR-2084, BT1886, Log3G12.
    Added: Frame Rate Override from Bin.
    Added: Frame Rate Override via R3D Trim.
    Added: OLPF Override via R3D Trim for clips recorded on DSMC swappable OLPF cameras.
    Added: Pixel Masking to map out pixels in post (not supported on Rocket).
    Added: Tether support for Frame Trigger mode.
    Added: Tether support for limiting the number of frames in a clip.
    Updated: CUDA performance improvements.
    Fixed: CUDA/CPU exports with 90 degree rotation produced incorrect output.
    Fixed: Incorrect H2O OLPF metadata name.
    Fixed: REDline works again under Mac OS X 10.11.
    Fixed: ProRes issues when viewed in QuickTime Player and Adobe Premiere on Windows.
    Fixed: ProRes audio playback with VLC.
    Fixed: Issues with some 2K modes on Blackmagic SDI output devices.
    WEAPON CF: https://www.red.com/downloads/55a01322f01b305ec100179a (download name will change after go live)
    WEAPON MG: https://www.red.com/downloads/56af8a8ccc11fa5a1b0020a4
    EPIC DRAGON: https://www.red.com/downloads/52b4914517ef02624c000017
    SCARLET DRAGON: https://www.red.com/downloads/538b61b52f74a95b28001816
    EPIC M-X: https://www.red.com/downloads/4f56854e6261f95a5700069b
    SCARLET M-X: https://www.red.com/downloads/4f56854e6261f95a570006ca
    REDMOTE: https://www.red.com/downloads/4fd907a426465a310b00015c
    REDCINE-X PRO: https://www.red.com/downloads/5340c33e26465a4b46002ddc
    Yay! My audio problem was fixed!!
    "Dream so big you can share!"
    Senior Member Luke Neumann's Avatar
    Apr 2012
    Oregon, USA
    HDR Gamma curves. Yes, yes, YES! Way to stay a step ahead on all fronts. Seriously...awesome.
    San Diego, CA
    My compliments to the RED chefs, this looks tasty...
    Cheers - #19
    Senior Member Matthew Quinn's Avatar
    Apr 2014
    Buffalo, N.Y
    Bing bang bong
    WEAPON HELIUM 8K
    SCARLET-W
    LOCAL 600
    BUFFALO, N.Y
    IMDB
    www.coderedpicturecompany.com
    Senior Member Tommaso Alvisi's Avatar
    Jan 2009
    ITALY
    great update thanks jarred!
    TOMMASO ALVISI | tommasoalvisi.com
    Weapon 6K Carbon Fiber #1605 aka qp
    instagram | twitter
    Jun 2008
    Germany
    Element Technica V-Mount Plate still shows 0% and shuts down camera after 25 seconds :(
    Weapon CF Monstro #1119, Weapon Helium, Epic-X #7926 BAM, Raven #220
    Dec 2010
    Toronto & Vancouver
    Eeeeee!!!! Is the speed of Cuda>OpenCL?
    Pixel masking in post!!! Me likey.
    Nov 2009
    Thanks guys !
    hooray !
    Senior Member roryhinds's Avatar
    Jan 2007
    Vancouver, BC, Canada
    Just picked up my Weapon CF today. Can't wait to play and get this sucker in the air
    Rory Hinds
    World Explorer
    Mine Films
    http://www.minefilms.com
    VANCOUVER, BC CANADA
    IATSE 669 Director of Photography / Drone Pilot /
    Writer / Director / VFX / Grading & Finishing
