Thread: IPP2
Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
  1. #11
    Aug 2011
    In REDCINE-X Pro
    After you make these changes, Restart Redcine-X so that they take effect when you reopen it
    Aug 2011
    Or Color Managed in Resolve Like Mike stated above
    Aug 2011
    Or This Combo
    Jan 2015
    Thanks for explaining how to pre-set this. I was lucky enough the last time I shot something on Epic Dragon that the colorist was knowledgeable enough to ask first.
    Aug 2011
    You're Welcome Matt!
    Aug 2011
    Apply CDL
    In Redcine-X or In-Camera
    Aug 2011
    Apply 3D Lut
    Aug 2011
    Apply Metadata Curves
    Aug 2011
    Davinci YRGB with IPP2 Transform LUTs applied at the end of Node Tree
    With "DAVINCI YRGB", you transform all of your RED .R3D files into a REDWIDEGAMUTRGB/LOG3G10 image at import. You will still need to add an "IPP2 OUTPUT TRANSFORM LUT" at the end of the Node tree to properly transform the image, It won't be done for you as in the "Davinci Resolve Color Managed" workflow above. However, you will be able to choose what "IPP2 OUTPUT TRANSFORM LUT" you want to use with each individual RED .R3D file instead of being locked into one for the entirity of the project like in the "Davinci Resolve Color Managed" workflow. You don't have to use the exact Nodes I labeled below in your workflow. Just a few, but use the last two nodes "CREATIVE Lut" and "IPP2 Transform"in that order.
    Aug 2011
    Another Way
    In Redcine-X Pro
    In Resolve
    When you bring the Red .R3D file into Resolve, It still looks flat like the RWG/LOG3G10 image should look. However, when you place the .R3D image on the timeline, the IPP2 Transform Lut you selected in the "3D Output Lookup Table" Menu takes affect
    OR
    Not select an IPP2 Transform Lut in the "3D Output Lookup Table" and use an IPP2 Transform Lut at the end of a Node Tree to transform the image
    Continued Next Post..........
