Thread: Footage Not Showing as Graded in Resolve and Premiere
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1 Footage Not Showing as Graded in Resolve and Premiere
    Junior Member
    Sep 2017
    I just updated my Epic-W to version 7.4.1. For some reason, all of the footage that is now shot on the camera shows up as ungraded. When I open the clip in Premiere or Resolve, it's showing as a flat, ungraded IPP2 clip. I'm on the latest version of Resolve (16.2.7.010). I also got the latest version of REDCINE-X, and clips DO show up graded and looking correct in there. I went through the camera settings and don't see anything that would cause this issue. Was there something changed in the R3D that other programs cannot interpret it now? Aside from putting on a LUT, I'm not sure what more I can do aside from reverting to an older firmware version.
    Aug 2011
    Mark,
    Do you have R3D frame or clip that exhibited this problem that you can share?
    Junior Member
    Sep 2017
    So it seems like changing the output transform settings in Premiere fixed the issue. "As shot" used REDWideGammutRGB for Color Space and Log 3G10 for Gamma Curve. Changing it to Rec.709 and BT.1886 respectively fixed it. Not sure if there is no color space and gamma curve specified in the metadata? Looking back at clips shot on the previous version, it never defaulted to REDWide/LOG 3G10. Seems like just this version is missing those specifics in the metadata.
    Junior Member
    Sep 2017
    More interesting discoveries: took a look at the RMD file. None generated by camera, but is when settings tweaked in RCP. Looked at output transform settings. By default, set to this:
    <bypassipp2outputtransform type="bool" value="false"/>
    Changing that false to a true made Premiere load it with the correct Rec.709 and BT.1886 values, showing a fully graded IPP2. Now the question is, does RED need to fix this in a software update, or is there something I can change in the camera?
    Aug 2011
    Mark,
    "True" should have done the opposite and given you a flat image.
    True
    False
    Also
    Did you check in Redcine-X to see if you might have had "Bypass IPP2 Output Transform"checked by mistake.
    Senior Member Loren Simons's Avatar
    Sep 2011
    RED is making changes to the default behavior of R3D’s in all third party applications to unify the results and deliver consistent and predictable behavior no matter what software you are working in.
    All R3D’s will be decoded in software such as Premiere, Resolve, and Final Cut Pro as Log3G10/REDWideGamutRGB by default.
    Most software, such as Resolve and Final Cut Pro, have ways to customize how R3D’s are decoded project or system wide - and so if a workflow that is different from the default is wanted, it can be configured applied to all future R3Ds in all future projects.
    Premiere is the one exception to this - with neither a true color managed workflow capability nor ability to change R3D decode parameters project wide.
    However, there is still a suitable workflow for Premiere which maintains true flexibility in color grading and is simple to implement.
    Our recommendation is to generate the desired IPP2 Output Transform from REDCINE-X, for example a Rec.709 with Medium Contrast and Soft Highlight Roll-off. Once that .cube is created, select that as the Creative LUT for one of your clips in Premiere’s Lumetri Panel. After that, simply save that Lumetri Panel as a Lumetri Preset by right clicking the top of the panel.
    This Lumetri Preset can either be applied to all of your R3D clips in your bin, or, the Preset can be dropped into a top level Adjustment Layer which runs the length of your timeline - automatically applying it to any image beneath it in the timeline.
    Either of these methods will delivery you a proper image, with the added benefit of still maintaining the full flexibility of your logarithmic image behind the resulting image when changing your Lumetri values.
    Previously, with images coming into Premiere directly decoded into say Rec.709 Medium Contrast Soft Highlight Roll-off, any adjustments made in Lumetri would happen on-top of that image, severely restricting your latitude in post.
    Loren Simons
    RED Digital Cinema
    Motion Picture Technology Advisor
    Aug 2011
    Like Loren stated above, it's something like this in Premiere.
    Sep 2011
    Thanks Rand! That is an interesting way of configuring it - essentially trying to mimic a node-tree from Resolve in Premiere.
    I usually take a more simple way of approaching it, where you essentially do what I've shown in this video, and then simply grade each clip using their own Lumetri settings.
    https://reddigitalcinema-my.sharepoi...Oa_vw?e=hlXrBy
    Loren Simons
    RED Digital Cinema
    Aug 2011
    Loren,
    Your way is much better!
    Aug 2011
    Loren,
    Using your method you could apply an adjustment layer above each clip with a preset IPP2 Transform preset applied.
    IPP2 Output Transform Medium Con/Soft
    IPP2 Output Transform High Con/ Very Soft
    IPP2 Output Transform Low Con/ Medium
Tags for this Thread
View Tag Cloud
