Thread: Redcine-X too wide for 13" screen
Results 1 to 5 of 5
  1. #1 Redcine-X too wide for 13" screen
    Senior Member Robert Hofmeyr's Avatar
    Sep 2009
    South Africa
    Maybe I'm missing something, but I can't seem to fit Redcine on a 13" laptop screen. I need the viewer, media and image panes, but when I have them all open, either the left or right side gets pushed off the screen. Is there a way to make the viewer smaller?
    Are you saying you're unable to resize the viewer by dragging the left or right edges of it?
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Sep 2009
    South Africa
    Hey Phil. I can resize it a bit but not enough to fit the media tab on the left and the Image tab on the right. Once the buttons/info above the viewer run out of space, I can't make it any smaller. See screenshot attached.
    Sep 2011
    Is your screen set to max resolution? This happens on my 15" MBP, unless I select the furthest 'more space' option in the display settings.
    Sep 2009
    South Africa
    Quote Originally Posted by Chris Sharman View Post
    Thanks Chris. It was set to default. Setting it to more space does fix the problem, but then the text is a bit small.
