Thread: spot on the footage
Results 1 to 9 of 9
  1. #1 spot on the footage
    I have a round spot that can be seen on the far right of the footage. We cleaned the lenses and did a test with two different lenses. We don't see the spot from 2.8 -11 but after that the spot is noticeable. all the way to 22. We even did testing on different setting on the ISO
    I was wondering could it be the sensor may have artifact on it or is it something farther into the camera? Thanks
    Working blind, but if you have an R3D Snapshot or high res jpg it's easier to see what's going on.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Yes I can pull still frames from the footage. is there a way to post it on here?
    actually I can post a video
    its a round spot which can be seen a bit down below the word Spot. youtube footage seems to show the footage a bit dark.
    https://www.youtube.com/watch?v=beDUdi0IJrY
    If that appears on every lens I would examine your OLPF.
    Looks like something got on there.
    phfx.com IMDB
    PHFX | tools
    Red Weapon/DSMC2
    Red Dragon
    Senior Member Jon Shaw's Avatar
    Apr 2008
    Sydney, Australia
    Sounds like a spot on the OLPF, needs cleaned
    Jon Shaw ACS
    ginclearfilm
    Sydney
    Australia
    I found a camera shop in Orlando that will clean the full camera inside and out for $220. I wouldn't be a bit surprised if the camera never had a cleaning before.
    Quote Originally Posted by Fred Potts View Post
    It´s the sensor / oplf that needs cleaning take like 10 minutes and any rental house has a guy that can do it or you can do it yourself. 220USD seams a bit steep. A bottle of wine is usually more than enough.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
