Thread: Any way to add a 2nd SDI out to the Komodo ?
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1 Any way to add a 2nd SDI out to the Komodo ?
    I just got my Komodo - yeyyy :)
    Then I tried to connect both a monitor and a wireless transmitter without looping - oops, Komodo has only 1 SDI port...
    Is there any way to add a 2nd SDI out to the Komodo ?
    You kind of want to have a screen with in /out SDI.
    I use the Vaxis atom 600 TX it has SDI and HDMI out + wireless... solves a lot of problem with one stone.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    Vaxis Atom 600 looks great, but I have Teradeks...
    Would there be something like a "break box" that has SDI outs?
    The RED Komodo's own "expander module" has 3 connections that look like SDI, but are labeled as "GPI" , "Genlock" and "Timecode".
    Could I use any of those as SDI out ?
    Quote Originally Posted by Emilian Dechev View Post
    No. The expander module does not have SDI out(although they are BNC’s).
    Which Teradek? Most have a loop-out. But my recommendation would be to have a monitoring device(monitor of VF) that has a loop-out/pass-thru and go into that FIRST, because you don’t want any (extra) delay on the image that you’re using to shoot by.
    Yes the Teradek has a loop, but I wanted to avoid that for the same reason.
    Funny thing is, that SmallHD made the "Focus Pro Komodo Kit 5 inch" monitor, to be specifically useful with the Komodo - having the control protocol for the camera is very nice. But this very same "specifically made for" monitor, lacks a SDI loop.
    So, thanks to SmallHD, now I have to choose between having a camera control, or having SDI loop.
    I'm using the Cine 7 most of the time on Komodo which has SDI and HDMI Outs.
    The Indie 7 is has SDI Out as well, but that came out well after I nabbed the Cine version.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Indie 7 also has Komodo control?
    Ok that may be a solution, although I was looking for a lightweight setup overall, like a 5 inch something...
    Junior Member
    Nov 2012
    Philadelphia, PA USA
    +1 for the Cine7. I've had it for a while now and find myself using SDI to SDI or SDI to HDMI loop out often.
    rcbandit.com
    But nothing exists in 5" ? With camera control I mean.
    Junior Member
    Nov 2020
    has anyone ever tried the freakshow hd sdi splitter? Maybe this might be an easy onboard solution to get a second sdi port.
