Thread: 1.8X Anamorphic squeeze
Results 1 to 8 of 8
  1. #1 1.8X Anamorphic squeeze
    I am currently on a show directing 2nd Unit. We are using Panavision 1.8X T series anamorphic (which are cool). and it seems I am limited to full 8K to 60fps. I think there might be a firmware hack to fix this and maybe get 80fps. What does anyone know about this?
    Doubt thats the case. Framerate is set by the number of vertical pixel rows so if shooting full height of the 8k sensors you will not get 80fps.
    Björn Benckert
    +46855524900 www.syndicate.se/axis
    VFX / Flame / Motion capture / Monstro
    San Diego, CA
    Pretty sure Björn is correct.
    Cheers - #19
    Senior Member Chris Kennedy's Avatar
    Jul 2009
    Fort Lauderdale, Florida
    If you were to shoot spherically and crop to 8k WS then your max frame rate would be 75fps. But since you are shooting anamorphic and using the full sensor height, then it's 60fps
    Red Weapon Helium
    GL Optics Leica R
    Nikkor
    Looking forward to finally using my Hydrogen with whatever Komodo is...
    PresidentialFilmPhoto.com
    Cinematography & Fashion/Glamour Photography
    Hi Peter,
    No known hacks here, but you can use a framing guide and a res/format change and shoot 6K FF's height to achiever higher FPS, much like switching resolutions normally.
    phfx.com IMDB
    PHFX | tools
    2X RED Monstro 8K VV Bodies, 1X RED Komodo, and a lot of things to use with them.
    Data Sheets and Notes:
    Red Weapon/DSMC2
    Red Dragon
    Oct 2017
    Rotate lens-camera 90 degree? Anamorphic hack.
    Phil, I am using your FPS guide my friend. Thanks
    This is a really good post imma do my part by help keeping it going.
